Flatten surface result
ben_partouchben_partouch Member, csevp Posts: 158 PRO
Hello,
When I export the flatten surface output, the dxf/svg is very messy, broken and not closed.
The same surface exported as a flattened sheet metal is much better.
Any solutions?
Thanks
  • S1monS1mon Member Posts: 3,835 PRO
    Hmmmm. I noticed that the edges are not always the cleanest curves, but I didn't run into them being not closed. Can you share an example? It sounds like something that you might want to report to support.
  • ben_partouchben_partouch Member, csevp Posts: 158 PRO
    I exported the dxf to vcarve and it works much better….
    Thanks @S1mon
