Auth JS Setup for Easy OAuth
DavisCCRDavisCCR OS Professional Posts: 13 ✭✭
I am attempting to create an element tab app with Next.js and Auth.js. It seems like it would be easy but no matter what I (or Cursor) try I either run into CSRF errors or invalid requests to the Onshape APIs. I know there is a working example with Passport I just thought it would be cleaner to do it with Auth.js.
This is the auth.ts file I revert back to every time I try something and fail:
// /src/auth.ts
import { OAuthConfig, OAuthUserConfig } from "next-auth/providers";
import NextAuth from "next-auth";
import type { JWT } from "next-auth/jwt";
interface OnshapeProfile {
  email: string
function Onshape(config: OAuthUserConfig<OnshapeProfile>): OAuthConfig<OnshapeProfile> {
  const baseUrl = "https://cad.onshape.com";
  const apiBaseUrl = "https://cad.onshape.com/api/v10";
  return {
    type: "oauth",
    authorization: {
      url: `${baseUrl}/oauth/authorize`,
      params: { scope: "OAuth2ReadPII OAuth2Read" },
    token: `${baseUrl}/oauth/token`,
    userinfo: {
      url: `${apiBaseUrl}/users/sessioninfo`,
      async request({ tokens, provider }: { tokens: JWT, provider: OAuthConfig<OnshapeProfile> }) {
        const profile = await fetch(provider.userinfo?.url as URL, {
          headers: {
            Authorization: `Bearer ${tokens.access_token}`,
            "User-Agent": "authjs",
        }).then(async (res) => await res.json())
        return profile
    profile(profile) {
      return {
        email: profile.email,
    options: config,
export const { handlers, auth } = NextAuth({
  debug: true,
  providers: [Onshape({
    clientId: process.env.AUTH_ONSHAPE_ID,
    clientSecret: process.env.AUTH_ONSHAPE_SECRET,
  callbacks: {
    authorized: async ({ auth }) => {
      return !!auth
I have tried giving Cursor the passport examples and telling it to replicate the behavior in the callback functions but had no luck.
I have experimented with the middleware a bunch but right now it is just:
// /src/middleware.ts
export { auth as middleware } from "@/auth";
This is my OAuth setup in the developer portal:
Redirect URL: https://localhost:3000/api/auth/callback/onshape
OAuth URL: https://localhost:3000/api/auth/signin/onshape
I am running it locally with a self signed certificate but I get the same errors when hosting in on Vercel.
If anyone has solved this or knows how to then I could make a pull request to add it to the built in providers of Auth.js.
