Add a spline to a tapered plug
robert_ikinrobert_ikin Member Posts: 4
This is so simple it's madding, I've created a tapered plug using revolve and now I need to add a spline to the curved surface, I thought I could extrude an arc on the curve and use the circular pattern to repeat around the plug, I created an extrude via a sketch on one end but I can't get the extrude to match the plug taper, is this the right approach or is there another way to do it?
  • glen_dewsburyglen_dewsbury Member Posts: 1,255 PRO
    Can you post a link to your document for review?
  • Matt_ShieldsMatt_Shields Member, Onshape Employees Posts: 894 PRO
    Without the document, it's hard to see what you're talking about. But, an extrude with a direction (highlighted in first image) would work. Or a revolved remove just a few degrees (20 degrees in the second picture).
    Screenshot 2025-02-04 at 8.41.36 AM.png Screenshot 2025-02-04 at 8.42.04 AM.png
  • rick_randallrick_randall Member Posts: 412 ✭✭✭
    Could I ask why the splines need to be on a "tapered" plug? You may have a valid reason for this, but I'm not making the connection of why you would need this. It is an interesting abstract problem though.
  • robert_ikinrobert_ikin Member Posts: 4
    Thanks for the tips, I'm trying to produce a set of CAD drawings for the gears of an old (30+ years) automatic shed door setup. Long story short, the originals stripped late last year. I managed to produce some drawings, which I printed and tried, they were close enough so I produced a set of Nylon CF ones as a temporary measure, they're OK but not hard enough for a permanent fix. There are two gears, one I've got right, the other, the drive gear had a cut recessed tappered splined mounting which I can't get right, it's ok with nylon I can use the threaded drive shaft and force it to fit.
    I want a set of steel ones made, thence the need for good CAD drawings, with the drive gear my idea was to create a plug with the tapper, spline and cut out and extrude through the drive gear, Good, bad I don't know this is all new to me.
    https://cad.onshape.com/documents/1afd2cb8eb6f733fd2ea06e8/w/9f84602adc9ac4212238f82a/e/04d6b1bfe58a9ea573f46d4e
    https://cad.onshape.com/documents/1afd2cb8eb6f733fd2ea06e8/w/9f84602adc9ac4212238f82a/e/d004b63bc31ee0a5d3999f85
