Fewest features to create a hexagonal surface
jeff_mcaffer
jeff_mcaffer Member Posts: 108 ✭✭✭
edited February 2025 in Community Support
In the context of another problem, I needed to create some flat surfaces that have "complex" perimeters. I'll use a hexagon here but the real surfaces may have more complex perimeters. I tried a few things in this document flat surface | offset surface.
  • Extruding a surface sounds enticing but that make surfaces out of the perimeter elements not the enclosed shape. similarly for "thin" extrusions
  • Extruding solid and deleted the unneeded faces leaving just the top (or bottom) surface. That works but for complex perimeters, there can be many faces to delete.
  • Extruding a solid, then offset the face you want and deleted the extruded part. That's just three features but still seems like (two) more than would/should be required.
Question is, what's the "right" or "simplest" way. I've not done a lot of surface modelling so am surely missing something… Feels like doing a "solid" extrude with a blind depth of 0 would be a (somewhat) intuitive way of thinking about it.
