Error in "Tech Tip: Selectively Remove Unwanted Actions in Your Onshape Document History"
Regarding this web page: Selectively Remove Unwanted Actions in Your Onshape Document History
If you follow the instruction in the second method for removing multiple actions, you will inadvertently also remove one additional action taken after the actions that you wish to reverse. The example shown in the pictures, would result in the "Spool :: Edit : Revolve 14" action also being undone.
Specifically, search for the phrase: "create one on the first action after the deletions". To be accurate, this phrase should be replaced with: "create one on the last deletion", and of course the images should be updated to match.
Also, the Extra Tip: "You can delete the branch workspace once the restore is complete. If there are no versions on the branch, it completely removes the branch from Versions and History." is incorrect. The branch can be deleted, but the line showing the branch and merge is still there. I think that is a feature, not a bug, but the text of the "Extra Tip" should be changed so that it doesn't imply that this action will not be visible in the versions and history graph.
