How can I hide the point used to make a point-plane?
Colin_Eichinger
Member Posts: 4 PRO
I have inserted a couple of planes for use in a model using the "select a point and plane" option. The point used to create these planes now stays visible even if all sketches and planes are hidden. How do I get rid of these?
MichaelPascoe
Member Posts: 2,739 PRO
Right shift + P
If that doesn't work, the graphics cache could be stuck, you may have to hard refresh your browser, or close it then open it again.
CADSharp - We make custom features and integrated Onshape apps! Learn How to FeatureScript Here 🔴1 -
MichaelPascoe
It's the hot key for hiding everything that isn't a surface or a body. You can see the list of hot keys here:
CADSharp - We make custom features and integrated Onshape apps! Learn How to FeatureScript Here 🔴0
Right shift + P
That worked, thanks! If I can ask a follow-up, what is that hot key for, just hiding all visible points?
