Feature request: Configuration panels and tables
nicholas_withamnicholas_witham Member Posts: 17 ✭✭
We need the ability to rename configuration columns, and also be able to re-order those columns at any time.
I've seen a number of people asking for these improvements but haven't been able to find an improvement request.
You can see the below tables only reference to the type of feature/dimension it references to. Being able to add a title would be very helpful.
Column titles should be unique within the table, but be able to be duplicated across tables.
Being able to shift the columns left and right at any time is also essential, along with being able to shift the rows up and down.
  • jelte_steur_infojelte_steur_info Member Posts: 634 PRO
    renaming the feature, renames the column. makes your feature tree better as well.
    For sketch dimensions, its a tiny bit more cumbersome, but you could make a bunch of variables, use those in the sketch and drive themin the configuration table… the variable names are the feature names and they'll show up
    all those variables (as long as they don't depend on each other) can be put in any order you'd want.
