Best practices for how to edit curves used for loft guidelines?
kenn_sebesta167kenn_sebesta167 Member Posts: 113 ✭✭
Lofts require that guidelines and paths intersect precisely, but the edit curve functionality doesn't have a way to enforce that intersections are preserved. So I can start with a curve, e.g. a 3D spline, which originally intersects the loft profiles but after the edit curve feature is complete there will be minor discrepancies and the guideline will fail.
I've been trying a variety of things for an hour now, but it seems like either the tool I want doesn't exist (e.g. a way to constrain an edited curve's point along another pre-existing curve) or simply can't exist (some kind of magic which would let me back propagate the new curve points to the original loft profiles).
Thoughts?
  • S1monS1mon Member Posts: 4,046 PRO
    The only way right now to enforce intermediate points to be coincident is to use a sketch or a 3D FitSpline. If your curves can be planar, I would recommend using sketches and Bézier curves.
  • rick_randallrick_randall Member Posts: 416 ✭✭✭
    @kenn_sebesta167 - I find the "pierce" command is very handy for this use, and I prefer it to coincident, most of the time (it just seems more robust).
