Support to rotation part, cap and stand
chandrashekar_rchandrashekar_r Member Posts: 50
https://cad.onshape.com/documents/34de2e0d48dd80fe7c7666cb/w/77f41324247b93f148493d72/e/d1616f53a31a815b1b7ef794?renderMode=0&uiState=67b1f8ede9a9070fcc91c951
Hi
I am almost in last phase of project and this is my first project after going through tutorials and vidoes :)
I am unable to figure out how to do the following and hence this post
As you see in assembly
The blacde part is placed inside bowl
The blade part is a rotational part, so it just cannot be placed as it is in the bowl
There should be a support from bottom of bowl to top of blade so blade rotates correctly
need a cover on top to cover the blade and on top of cover i need mount to fix stepper motor
lastly i need to make a stand to the project so the whole bowl sits firmly on stand
