How to move parts in a different assembly (like same assembly but different tab).
Please, i need help, this is for a robot that is due soon
  • David_YL_NguyenDavid_YL_Nguyen Member, Onshape Employees Posts: 182 image
    Hey @nigeria_germany,
    Add an assembly tab to the document and insert the parts you want in the assembly. More info here: https://learn.onshape.com/courses/introduction-to-assembly-design
  • martin_kopplowmartin_kopplow Member Posts: 1,176 PRO
    Have you tried the "Derive" feature?
  • nick_papageorge_dayjobnick_papageorge_dayjob Member, csevp Posts: 1,046 PRO
    You don't have an assembly. Have you used one yet? The point of an assembly is to place parts from all different part studios (which is what you have now), and different documents, into the same place.
    You can use derive to do what you are explicitly asking. But if you are not using assemblies now, derive will be only a quick fix for this one specific case.
  • nigeria_germanynigeria_germany Member Posts: 4
    i am curently on website, i dont know if i have these same features… i am beginger so i dont really know
    It is a cloud based system, so everyone accessing it through a webbrowser sees the same full set of features (as opposed to using an app, then you might see less). As already pointed out: You use part studios to create parts, be they individual or even small sets of closely related parts. Then you use an assembly to put all your parts together into your product.
    To get back to your initial question: That way, you "insert" the parts into the assembly, which kind of brings them into another tab, as you desired.
    There are quite comprehensive tutorials on all this in the Onshape Learning Center.
