How do I connect vectors in a sketch?
korbin_strongkorbin_strong Member Posts: 5
No matter what I make the lines are all disconnected in DXF causing my arc droid to have to cut 2 separate L's instead of just a square in one go. The problem with that is that I have double the lead ins and outs and it making it hard to keep the lead ins and outs from hitting other parts near by. On top of that It makes a perfectly straight line have a little notch in it, even with a lead in and out. I know that a plasma cutter isn't crazy accurate especially on an Arc Droid but still super annoying. Oh, and doing coincident constraints on everything Doesn't make a difference at all. Doesn't matter if I'm making a square from default or from lines. Sometimes It's opposing corners and other times it's 2 corners next to each other and every once in a while its every corner. When I put my DXF file into Vcarve or Light burn from a buddies place, they both have some kind of combine vectors option. There's also a good chance I'm dumb too, lol.
