Wall creation fails when scale is changed
christian_becker332christian_becker332 Member Posts: 2
Hello,
I have created a body which I wish to hollow out. I use the wall option for that and it works fine. It creates a 2.5 mm wall automatically. Now I want the wall to be just 1.5 mm wide but if I change the scale the wall creation fails and onshape says that it failed but not why.
Can anyone help me?
Thank you.
  • S1monS1mon Member Posts: 3,961 PRO
    If you share a public link to the document… yes.
