How do I stop Onshape file from resizing in Draftsight?
jackie_1
Member Posts: 20 EDU
My drawing made in Onshape is very tiny when imported into a template in Draftsight. How do I maintain the correct size?
Got it!!!!! just needed to change units in Onshape. Onshape is so awesome!
5
Is the Onshape DWG in inch and DraftSight in mm? Are you inserting into an existing DWG or simply opening it?Senior Director, Technical Services, EMEA0
oops. sorry for the no click. Draftsight template is in inches I think. I am inserting it into an existing DWG template from NASA/PSU. This is the CELERE program. They require we make a drawing on their draftsight template. But... draftsight is very difficult to manipulate compared to Onshape. I can give you the online template....
scroll down to download testcell. it says a person must open it in draftsight https://spaceflightsystems.grc.nasa.gov/education-outreach/celere/how-to-apply/
draftsight drawing is in mm
I inserted my Onshape dwg sketch under the "insert" tab, "reference drawing". Do I need to set my Onshape units to mm?
5 -
and so are the forums!
I'm glad you fixed it yourself!Senior Director, Technical Services, EMEA0
Thanks Neil. I'm glad I did it with minimal help too! I even got my first badge points! I don't know, this program and organization can be very addicting!!!! Its all good!
2
