CAM Studio - Sheet Routers
Edgar_aspLEDEdgar_aspLED Member Posts: 4 PRO
Hello. I'm hoping to be able to use CAM Studio specifically with a sheet router style CNC machine (specifically the Haas SR100). Is there is a preset machine that is compatible or is there a way to define a custom machine that behaves as a sheet router CNC would? I've tried the generic Haas setting but I'm not sure that this will work with the ancient machine that I have access to currently. I currently use an old version of Surfcam to program my toolpaths and I'm hoping I can easily move that work into Onshape CAM Studio instead. Thanks in advance.
  • GWS50GWS50 Member Posts: 494 PRO
    I have a similar question. I've been using Aspire, MeshCam and VCarve on a sheet router that is quite old! but very reliable.
    It would be great to be able to set up these machines as user defined
