Flip an arc (mirror without duplicating)
vanowmvanowm Member Posts: 117 ✭✭
Is there an easy way to flip an arc without deleting and recreating it?
Just dragging itself or it's center point will distort it, I'm just looking for a way flip it to the bottom in this example.
Thank you.
  • S1monS1mon Member Posts: 3,857 PRO
    Not in Onshape. If you just need a curve and not a true arc, you can set up a Bézier spline so that it can easily be flipped from convex to concave. Here I just used a degree-2 curve (making this a parabola) and made the two control polygon sides equal.
  • jelte_steur_infojelte_steur_info Member Posts: 634 PRO
    edited March 2025
    dimension to the centerpoint and make it negative.
    this is only one solution for the sketch to solve this negative value.
    if you fix the radius and try flipping the geometry, it's not going to work…
  • vanowmvanowm Member Posts: 117 ✭✭
    It's unfortunate..Quiet often when I move stuff around which is not constrain yet, it flips the arc and there is no way flip it back without using undo or recreating it…
    I think it would be a useful feature.
