Feature Script: How to get the coordinates of a selected point for X and Y
Matthew380
Matthew380 Member Posts: 50 ✭✭
So I just started working on featured script and was trying to get the X coordinate for a point that you select. However I have no idea how to do that can someone help?
  • jelte_steur_info
    did you follow the course in the learning center?
    https://learn.onshape.com/learn/course/featurescript-fundamentals
    fromt the standard library Documentation:
    evVertexPoint (context is Context, arg is map) returns Vector
    Vector type
    A Vector is a non-empty array. It should contain numbers or lengths.
    Operators +, -, *, and / are overloaded for vectors, and other operations such as dot product are available. If a vector does not contain numbers or lengths, operations that assume number-like properties may fail.
    vector (x, y, z) returns Vector
    Construct a 3-dimensional vector.
    reading through the documentation you should figure out that you need the first entry from the array returned by evVertexPoint.
  • jelte_steur_info
    Vector type
