Sketching on plane generated with cPlane
Hi,
I'm using cPlane to create a plane at line angle which I want to sketch on.
cPlane(context, id + "cPlane", {
Then I'm creating the sketch plane:
var sketchPlane = evPlane(context, {
"face" : qCreatedBy(id + "cPlane", EntityType.FACE)
And finally creating the sketch:
var sketch = newSketchOnPlane(context, id + "sketch1", {
"sketchPlane" : sketchPlane
This feels inefficient, is there a way to sketch directly onto the plane generated by cPlane?
Thnak you.
you dont even need the cPlane, you can just do newSketchOnPlane and feed in a plane definition
www.smartbenchsoftware.com --- Renaissance --- Kestrel -- SmartLink
Experts in Onshape Automation - Custom Features and Integrated Applications0 -
Thank you - looking at cPlane source there is a function lineAnglePlane that generates the plane - it's pretty complicated.
Could you give me some pointers for defining a plane at an angle to an edge without cPlane please?
