Newbie question about surfaces
dan_telschowdan_telschow Member Posts: 4
Sorry for the newbie question. I was trying to create what seems to be a simple surface but it turned out to be more difficult than I expected. I had a sketch that had two squares. One offset inside of the other. What I wanted to do was create a surface of just the area between the two squares. I expected fill to work, but it didn't want to do it. I eventually used boundary surface, but I had to do it in 4 steps. One side of the square at a time. It seems like there has to be a better way. Any ideas would be super helpful. Thanks!
See the attached pic. I just want the area in orange to be a surface.
  • eric_pestyeric_pesty Member, pcbaevp Posts: 2,590 PRO
    The sketch face is basically a surface, depending on what you want to do next, this might be enough…
    You can convert your selected sketch face to an actual surface entity using the offset surface feature (with offset set to 0).
  • jelte_steur_infojelte_steur_info Member Posts: 650 PRO
    or use fill only on the outer square and split face → delete face the inner square.
  • dan_telschowdan_telschow Member Posts: 4
    You guys are great! Thanks for the help!
