How would I partially delete the bend?
levi_tracylevi_tracy Member Posts: 2
I am trying to design a sheet metal project with flanges but when I trim back peices to make room for others, I still get an error because it says the bend is in the way when it isnt. How would I partially delete the bend?
  • eric_pestyeric_pesty Member, pcbaevp Posts: 2,507 PRO
    Have you checked the flat pattern view, it looks like that's where the interference would be…
    Use the partial flange to make the flange shorter than you want and then add material back to it either with a tab or a sketch in the flat view.
    Or trim the other flange first to stop it from interfering!
