Newbie help needed. Revolute joint pins "Shearing" not recognised as solid bodies
paddy_kingpaddy_king Member Posts: 13
Having the same problem with 2 linkage assemblies with the first 2 Revolute pins entered working correctly in both applications but the third pin appears to be OK, but is ignored as if invisible to links when movement is started. All surfaces appear to be correctly aligned in their planes etc.
In the case of the Jansen Leg linkage 10 pivot points are required, have seen a reference to using an alternative function to revolute for additional joints? any help appreciated
Ref slider
https://cad.onshape.com/documents/462d599d08ddb15b245137f5/w/2952eb77fd8e524aa2323cd5/e/608f82e5cd336760969c14b7?renderMode=0&uiState=67ca2e1d5c57510ba7c804b1
Ref Jansen Leg
https://cad.onshape.com/documents/3b97a08811416b31d09eae95/w/2308bdae0e4d3c66a5214237/e/2db5b2332b5b00b4afbaf726?renderMode=0&uiState=67ca2c83fc067964c0570249
    I changed one of the revolute mates to cylindrical. Some times because of using real numbers there can be an ever so small error in alignment using revolute mates. Also if you want to have slide move the full distance of rail, the grey arm needs to be out board of the blue arm.
  • paddy_kingpaddy_king Member Posts: 13
    Thanks Glen will give it a try and report back
  • jamie_sullivan073jamie_sullivan073 Member Posts: 2
    this looks applicable as well. I am facing a similar issue but the dimensions are different. This gave me an idea that I can apply this thing on my problem as well.
    I need to learn from this error as well!! picked the link between the 2 levers as it is easy to check positioning etc,with the space behind .Also is what will be required on the multiple joints on Jansen leg Mechanism.
    Cylindrical partly works with the Pin locked to the short lever. but still passes through the the longer link. I aligned the 2 faces on the pin and short arm, because the pin is longer than required.
    My apologise for being a slow learner!
    Here it is with the blue arm able to swing right round. The slider pin is updated using in context.
    https://cad.onshape.com/documents/f0657abc6e9267ad53969cc9/w/4b1dea7b223b026aa8159840/e/b2adebb9d5a4389770bc6638
    Thanks Glen
    Will experiment some more,. Think for the Jansen Leg Linkage will try Male and Female Links with extruded pins as part of link and avoid having any loose pins to insert.
    All part of learning curve
