Loft with 2 profiles and multiple edges in each profile?
I have two arrays of edges for top and bottom faces, how do I use opLoft() function to create a single surface around the edges between top and bottom faces?
At the moment I can iterate the arrays and create separate lofts between two edges, I'm looking for a way to make it as one loft.
Thank you.
If it's a solid loft you are trying to create , then you need to pass in faces for the profiles.
If it's a surface loft then you can pass in edges or faces:
e.g.opLoft(context, id + "loft1", {"profileSubqueries" : [ e1, e2 ],"bodyType":ToolBodyType.SURFACE,});….where
e1ande2are queries for the edges0
