Can't extrude main body of dxf
christopher_lebachristopher_leba Member Posts: 4
Can't figure out why I can't extrude the main body of this dxf, I keep getting "failed to regenerate properly: Failed to extrude selections, check input".
I converted a JPG to DXF using inkscape bitmap tracing. Most images I did extruded just fine, a few kept getting this error. Google would suggest zero thickness parasolid limits but I can't find where this would be happening in this image.
Any help appreciated! https://cad.onshape.com/documents/a2b36c97ff6689efa267d1d8/w/f5d3152a712316c52f4bd51b/e/d481cf3d068e7886beae97f6
  • GregBrownGregBrown Member, Onshape Employees, csevp, pcbaevp Posts: 382 image
    edited March 2025
    If you use the Profile inspector in the sketch you'll find a number of "Loose ends"
    You need to tie up those loose ends… :) i.e. make sure that the vertices are coincident, and in some cases that there is no extra very short segment. Drag on one of the points as highlighted by the Profile inspector, then drag it back to make coincident.
    I also found one other intersection between segments that needed making coincident.
    You can get this pretty quickly:
  • christopher_lebachristopher_leba Member Posts: 4
    Thanks for the quick reply and pointing out the Profile inspector - that's really helpful. I cleaned up all the loose ends and now it's still giving me the same error when trying to extrude. Any tips here? You obviously made it work.
    https://cad.onshape.com/documents/14040394e70b1de9948e0a46/w/18e53d95dc3760649512907e/e/b6890d81cbf2b2b0f279fbd4
  • MDesignMDesign Member Posts: 1,332 PRO
    Secret tip to get to the bottom of sketch problems for imported sketches like this…. section it off with as many lines as it takes to narrow down the problem… like this. Your problem is stemming from a few lines like the second pic. teeeennnyyy tiiiiny lines hidden in the endpoints. remove those, maybe make the ends coincident and it'll extrude.
