Loose End hidden in construction line
stefan_freundelstefan_freundel Member Posts: 2
Hi all and thanks in advance for your time on this topic.
I will apologize in case I'm using the wrong way to solve my problem :-) I have a construction line on top of a standard line with loose ends.
However, I cant select the line from the graphics editor. It always selects the construction line instead of my original line with the loose ends.
Any suggestion how to solve the problem ? It's pretty anoying in the long run …
Thanks in advance
Stefan
  • MDesignMDesign Member Posts: 1,291 PRO
    Right click on the line then choose select other.
