Finding Drawings
gerald_friedmangerald_friedman OS Professional Posts: 50 ✭✭
edited February 2016 in Using Onshape
I've looked but not been able to find a way to go directly from a part model to its drawing.
Selecting the item in the parts list on the left of the screen lets one Rename, find properties, copy, create a drawing, etc. but not go to a drawing of the part if it already exists.
If it's possible let me know how.
If not, it might be worth adding. Searching for a drawing tab in a long list of parts is time consuming.
Also, in an assembly one can "switch to XXXXX" a part model. Would help to be able to switch to the parts drawing too.
g
    @gerald_friedman , Currently this facility is not available. You can use "search tab" option  as a work around in this case. In future we hope that this facility will be provided by Onshape.
    Search tab option available in Onshape image.
    Kindly refer below video for more detail.
