Sweep along split line
graham_lock
graham_lock Member Posts: 277 PRO
  • graham_lock
    I edited the initial post and corrected a syntax error on the sweep.
    The code shown now works.
  • graham_lock
    edited March 2025
    Hi,
    I'm trying to workout how to sweep along an edge created by a split in FS as can be done in the UI.
    The outline of my code is:
    // create plane at angle - THIS WORKS
    cPlane(context, id + "bodySplitter", {
    "entities" : qCreatedBy(id + config.longeronIndex + "skLine", EntityType.EDGE),
    "cplaneType" : CPlaneType.LINE_ANGLE,
    "offset" : 0 * millimeter,
    "angle" : planeAngle,
    "oppositeDirection" : false,
    "flipAlignment" : false,
    "flipNormal" : false
    // split solid body with plane - THIS WORKS
    opSplitPart(context, id + "splitPart1", {
            "targets" : config.solidBody,
            "tool" : qCreatedBy(id + "bodySplitter", EntityType.FACE)
    // use sweep to create a body using previously sketched profiles -  - THIS NOW WORKS
     sweep(context, id + "sweep1",
                    "bodyType" : ExtendedToolBodyType.SOLID,
                    "operationType" : NewBodyOperationType.NEW,
                    "profiles" : config.longeronProfiles[0].sketchRegion,
                    "path" : qNthElement(qCreatedBy(id + "splitPart1", EntityType.EDGE), 2),
                    "profileControl" : ProfileControlMode.NONE
    The sweep throws an execution error.
    I have a test document here which shows what I'm trying to achieve using the UI:
    https://cad.onshape.com/documents/b47247537a19de65742c7ceb/w/a1f3a56d0c6bdd4de138c226/e/135b3120a9f5267d9588c24a
    Any help appreciated.
    Thank you.
  • graham_lock
