Why can't I extrude the non-extruded part in the other direction?
ProApeProApe Member Posts: 234 ✭✭
Hello,
I want to extrude the non-extruded part of this sketch by 2.2mm in the opposite direction to the extruded part (see picture), but this is not accepted and I can't understand why.
Kind regards
ProApe
https://cad.onshape.com/documents/43c658f782ffde1134f6f1b8/w/26e8f556e08df7019e10d54d/e/5aed405ef9ab58a3240d8422?renderMode=0&uiState=67ed6361d1806a5a2ebb380c
  • MDesignMDesign Member Posts: 1,333 PRO
    I looked at this but it appeared things had changed from when you posted the question and couldn’t see the issue you were describing
  • ProApeProApe Member Posts: 234 ✭✭
    Yes, I had understood that I could extrude it as a new part.
    Unfortunately I couldn't write that without opening a new discussion as my question was not visible.
    I'm still astonished that this is the case here, unlike all the forums and communities I know.
