Versions as different parts?
mcconnell113
mcconnell113 Member Posts: 74 ✭✭
edited February 2016 in Community Support
Okay so what i'm really wanting to do is have two different pieces I create a first one and want to duplicate that one into it's own version then edit only that one. I've figured out that using versions seems to be the wrong way of doing this. How do i toggle between versions as not view only?
John McConnell - Let's change things.
Saplingstore.com
  • mcconnell113
    I believe I've figured it out. I can just duplicate the part studio. I still don't understand how to revert, it seems like some of the history is missing or something.
    Saplingstore.com
  • cody_armstrong
    cody_armstrong Moderator, Onshape Employees, Developers, csevp Posts: 229 image
    @mcconnell113 This seems like an ideal case for branching?  Have you tried that?
  • shashank_aarya
    shashank_aarya Member Posts: 265 ✭✭✭
    @mcconnell113 Do you want to create duplicate of any part and change only one part so that it will automatically update another part which is duplicated? In such case you can use "derived" option in another part studio. This will keep the associativity between two parts. Refer the below screen image
    After creating the first part, you can just click "Derived" option in another part studio which will allow you to select the the available parts,sketches, surfaces etc. available in the document.
