Failure with a OP boolean subtraction
Matthew380
Matthew380 Member Posts: 50 ✭✭
So I am working on a project that auto lofts something to a shape or point without 2 surfaces, and when I did remove in the part studio, it would not merge with the boolean:
However, at the same time, there are no error messages and nothing that says anything is incorrect. I also tried to see if the IF statement just wasn't working, but I checked tha,t and it goes through the statement
What is happening?
Here is the document:
https://cad.onshape.com/documents/94e2ca3c499ecbba9ccfafe6/w/c35c00116423894cfa81ae88/e/1fd4bc6d010a97fc9bf50bf5
    It is working, you just need to delete Part 2 - don't assume that subtraction removes the tools.
  • Caden_Armstrong
    What error are you seeing?
    The feature seems to be working just fine.
    Learning to debug might help you solve your issues.
    I wrote a blog with some tips and tricks on how to debug, functions like AddDebugEntities and debug arrows can be really helpful.
    https://www.smartbenchsoftware.com/post/a-quick-guide-to-debugging-featurescript
  • Matthew380
    I said no error was showing it just would never merge the parts together:
