Failure with a OP boolean subtraction
So I am working on a project that auto lofts something to a shape or point without 2 surfaces, and when I did remove in the part studio, it would not merge with the boolean:
However, at the same time, there are no error messages and nothing that says anything is incorrect. I also tried to see if the IF statement just wasn't working, but I checked tha,t and it goes through the statement
What is happening?
Here is the document:
https://cad.onshape.com/documents/94e2ca3c499ecbba9ccfafe6/w/c35c00116423894cfa81ae88/e/1fd4bc6d010a97fc9bf50bf5
  • NeilCooke
    NeilCooke Posts: 6,097 image
    It is working, you just need to delete Part 2 - don't assume that subtraction removes the tools.
