[Help] Hole wizard diameter behaviour
Siaunen2Siaunen2 Member Posts: 2
Today i try to play around with hole wizard tool on onshape, especially the 'tapped' section.
For the Metric - Simple - Tapped - Straight Tap the default value is M5 and the diameter is 5mm.
When i bump up the value to say M48, the diameter become 43 mm. This behaviour is expected, but when i go back to M5, the diameter still on 43 mm.
I can "reset" by launching the tool again, but the problem is if i want to make the hole under M5, let say M2, the diameter already 5mm. Is this behaviour only on my end? I test with different document still having same problem. How do i fix it?
  • GregBrownGregBrown Member, Onshape Employees, csevp, pcbaevp Posts: 381 image
    Have you submitted a support ticket on this?
