Assembly BOM in separate window
The ability to change component properties in the assembly BOM is very powerful. I often work in large BOMs with many columns, which makes it difficult to view BOM and model simultaneously.I would like to be able to pop-out the BOM into it's own window and have it on a different screen while keeping the "highlight the part when I click the Item number" functionality.
  • S1monS1mon Member Posts: 4,062 PRO
    Open a second browser window with the same document and put that on your second display. Use one window for the full BOM and the other for your assembly. I don’t think the highlighting will work across the windows, but you could have a narrow BOM view with highlighting, and a full BOM view without highlighting.
