Sketch constraints
göte_berggrengöte_berggren Member Posts: 5 ✭✭
In the Sketch dialog, checking the box of "Show constraints" does not work.
If it is replaced by the "Constraint manager" it should be removed for selection.
  • S1monS1mon Member Posts: 3,978 PRO
    Works fine for me. If there aren't any constraints, it will show nothing.
    Can you share a document?
  • martin_kopplowmartin_kopplow Member Posts: 1,216 PRO
    Yep, I confirm there is an issue. It does not show constaints in all situations. I check the box and constraints show up, but only for a short period of time, then they vanish one by one, until I uncheck the box and check it again.
    Sounds like something to send to support. I wonder if it's browser specific?
