figuring out the measuring tool
wesley_rishelwesley_rishel Member Posts: 11
Is this a bug?
When I look at the help page https://cad.onshape.com/help/Content/measure-ps.htm?cshid=measure_ps it seems to say that if I select s circle I should be able to see diameter, circumference and area. However when I look at a very simple part, Figure 1, I can.t seem to get those measurements. In Figure 2 I have selected the closed bottom and all I see is the area. In Figure 3 I ask specifically for Diameter and I am told that no measurements of this type are available for the selection. I finally figured out that I could measure the difference between the center and a point on the circle to get the radius, so I guess I have a work-around, but I'm wondering if I should report it? Or do I just not understand how it's supposed to work?
Figure 1
Figure 2
Document: https://cad.onshape.com/documents/69294337d4dfbfc409eaa76c/w/586d6778aaa673048cb06dbb/e/e912d1d8b59c2fcf7db45ba7
  • nick_papageorge_dayjobnick_papageorge_dayjob Member, csevp Posts: 1,046 PRO
    Pick the round face, not the flat face. Then it will show the diameter. Also ok to pick the round edge where the sides and top/bottom meet.
