Cannot resolve plane in Feature Script extrude
Hi,
I am new to Feature Script and I am trying to create one for placing, on a cylindrical part, a groove for a Seeger ring.
I need to remove from the cylinder using an area between two circles.
Before placing the opExtrude function, the script works and the sketch with the two circles is created.
After inserting the opExtrude, I receive the "Cannot resolve plane" error.
Can anyone tell me where I am wrong, please?
Here is the code
FeatureScript 2641;
import(path : "onshape/std/common.fs", version : "2641.0");
annotation { "Feature Type Name" : "Canal_arbore", "Feature Type Description" : "" }
export const Canal_arbore = defineFeature(function(context is Context, id is Id, definition is map)
precondition
annotation { "Name" : "Muchie arbore", "Filter" : EntityType.EDGE, "MaxNumberOfPicks" : 1 }
definition.Muchie_arbore is Query;
// Get the plane of the selected face
var Plan_muchie = evPlanarEdge(context, {
"edge" : definition.Muchie_arbore
var Muchie = evCurveDefinition(context, {
var Raza_muchie = Muchie.radius;
println(Raza_muchie);
var Raza_int = Raza_muchie - 1 * millimeter;
// Create a sketch on the selected face
var sketchId = id + "toolSketch";
var toolSketch = newSketchOnPlane(context, sketchId, {
"sketchPlane" : Plan_muchie
skCircle(toolSketch, "circle1", {
"center" : vector(0,0) * millimeter,
"radius" : Raza_muchie
skCircle(toolSketch, "circle2", {
"center" : vector(0, 0) * millimeter,
"radius" : Raza_int
skSolve(toolSketch);
opExtrude(context, id + "extrude1", {
"entities" : qCreatedBy(id + "toolSketch", EntityType.FACE),
"direction" : evOwnerSketchPlane(context, {"entity" : definition.Muchie_arbore}).normal,
"endBound" : BoundingType.BLIND,
"endDepth" : 2 * millimeter,
"startTranslationalOffset" : 2 * millimeter
opThicken(context, id + "thicken1", {
"entities" : qCreatedBy(id + "extrude1", EntityType.BODY),
"thickness1" : 0.1 * inch,
"thickness2" : 0.1 * inch
opDeleteBodies(context, id + "delete1", {
opBoolean(context, id + "boolean1", {
"tools" : qCreatedBy(id + "thicken1", EntityType.BODY),
"targets" : qOwnerBody(definition.Muchie_arbore),
"operationType" : BooleanOperationType.SUBTRACTION
Solved it, thank you!
Start with reading the error message:
"evOwnerSketchPlane: CANNOT_RESOLVE_PLANE"
If you read the documentation for this function, you'll find that it is expecting a sketch entity.
Your feature is selecting an edge, which is not a sketch entity.
You don't even need to find the plane again here, since "Plan_muchie" already exists. Just use Plan_muchie.normal
Its good practice to read the documentation and see if the function inputs match what you are putting into it.www.smartbenchsoftware.com --- Renaissance --- Kestrel -- SmartLink
Experts in Onshape Automation - Custom Features and Integrated Applications0 -
Sorry Caden, but I don't understand, I'm an absolute beginner in Feature Script.
I've tried different solutions for the "direction" argument of opExtrude and for the "entity" in evOwnerSketchPlane, but none worked.
I tried also evPlane instead of evOwnerSketchPlane, no result.
I've read the documentation, it seems pretty clear, but I really don't know what I'm missing.
