How to export my sketch, which has images, into SVG or similar image file?
james_s663
Member Posts: 2 ✭
I'm trying to create a sketch for printing or laser engraving with some recognizable tags, whose images I imported and sized and positioned within a sketch of a plate. Images attached.
However when I try and create a drawing, I don't see the tags (from the imported images).
How should I best get an appropriate export for this? It's just a design to be printed on a 3' by 1.5' sheet of plastic or aluminum. I also made a quick part by extruding it 1/8", but it's the sketch that matters I think.
Thanks!
hey @james_s663,
Right-click on your view and "show shaded view"you should then see the decals. Try to export as .dxf
