Two questions about designing the case for pcb
dominik_panas
Member Posts: 17 ✭
I designed pcb for my keypad in Kicad. As far as i know i need to export (plot) my design (only the the layer with borders and holes)
- To what format i should export/plot it to import it easily in onshape?
Once i import it as a sketch i want to extrude it not in usual way. The "base" should not be parallel to the sketch but in angled plane. I probably should use additional plane in angled position. But even then how to extrude it not perpendicularly to the sketch but to the X or Y or Z. Like this (my very simple section view draft)
