How do you change a 2D model to a 3D model?
simbongile_mrwashusimbongile_mrwashu Member Posts: 2
  • robert_scott_jr_robert_scott_jr_ Member Posts: 759 ✭✭✭
    Hello, and welcome to Onshape. Your question is too broad to be answered in this scope. Onshape has all the tools needed to create a 3D model. The same model could be built by different users in different ways and not always using the same tools. You will need to learn how to use Onshape's tools in order to do what you ask. Once you begin to build your model you will have some difficulty along the way and here is one place where you can get help with specific questions. Go to the Learning Center to get started and find what Onshape has to offer. - Scotty
  • MichaelPascoeMichaelPascoe Member Posts: 2,808 PRO
    Like Scotty mentioned, the Learning Center is where it's at. I recommend starting with Onshape's CAD Basics Learning Pathway. It will show you everything you need to know.
    RENDERCAD
