Anyone know how to get part studio configuration variables via the API?
darren_lynchdarren_lynch Member Posts: 3 ✭✭
I was expecting something like this to work:
def from_did_wid_eid(did, wid, eid):
  Retrieve valid configuration variables for a Part Studio in Onshape.
  Parameters:
  - client: An instance of the Onshape client
  - did: Document ID
  - wid: Workspace ID
  - eid: Element ID
  Returns:
  - A list of configuration variables with their details
  client = _sop.get.api_client.from_dot_env()
  config_info = client.part_studios_api.get_part_studio_configuration(
      did=did,
      wvm="w",
      wvmid=wid,
      eid=eid,
  return config_info #Expected something, got None
  • Caden_ArmstrongCaden_Armstrong Member Posts: 371 PRO
    In the documentation its this endpoint:
    https://cad.onshape.com/glassworks/explorer/#/Element/getConfiguration
    I don't use the python client, but its probably under some kind of elements_api instead of part_studios.
  • darren_lynchdarren_lynch Member Posts: 3 ✭✭
    edited May 2025
    Thanks @Caden_Armstrong that helped.
    For anyone doing this in the future, not sure the python sdk response is working correctly, if you run this:
    import json
    import simscale_onshape_playground as _sop
    def test_sdk_vs_raw_response():
        did = "did"
        wid = "wid"
        eid = "eid"
        print("=== SDK Method Response ===")
        config_info = client.elements_api.get_configuration(
            did=did,
            wvm="w",
            wvmid=wid,
            eid=eid,
        print("Object type:", type(config_info))
        print("vars(config_info):", vars(config_info))
        try:
            print("to_dict():", config_info.to_dict())
        except Exception as e:
            print("to_dict() failed:", e)
        print("\n=== Raw API Response ===")
        # Patch broken endpoint to allow call_with_http_info to work
        client.elements_api.get_configuration.settings["servers"] = ["https://cad.onshape.com"]
        raw_response = client.elements_api.get_configuration(
            did=did,
            wvm="w",
            wvmid=wid,
            eid=eid,
            _preload_content=False,
            _return_http_data_only=False
        raw_json = json.loads(raw_response[0].read().decode())
        print(json.dumps(raw_json, indent=2))
    if __name__ == "__main__":
    You get an empty object, but if you include _preload_content=False, _return_http_data_only=False you get something, but then you need to process it.
