Loft problem
tyler_geiger873
tyler_geiger873 Member Posts: 11 EDU
so basically im making this thing and i have all these constraints and stuff but when I go to loft it and try to use guids or path they don't work I can only get it to work without them but I need them, can I get some help?
https://cad.onshape.com/documents/2e559d51465c960ecc2071ec/w/18a8db6e194f3f7a1ee57f69/e/f8944e8860685539cc359774?renderMode=0&uiState=6823616b76129c6ea9b779a5
  • Matt_Shields
    Looking at your model, a few tips.
    • When possible, take advantage of symmetry. Don't make the whole part. Make half or a quarter and mirror.
    • Loft surfaces, rather than solids. Then thicken or enclose.
    • If you are going to use a guide. Use the Pierce constraint to make sure the profiles and guides intersect. In the picture below, I used the Split sketch tool to split your profiles into 1/4 of the part. I also deleted some dimensions and added Pierce constraints.
  • Matt_Shields
  • tyler_geiger873
    so I pierced all of the edges and did what you said but it still says all guids should intersect profiles or something like that what am I doing wrong, here's the link now https://cad.onshape.com/documents/2e559d51465c960ecc2071ec/w/18a8db6e194f3f7a1ee57f69/e/f8944e8860685539cc359774?renderMode=0&uiState=68277da6105a6069773630c7
