How do I loft this
marco_van_soestmarco_van_soest Member Posts: 2
The loft feature en myself are not that good friends. I want this to parts to loft and tried everything (I think) but it won't even try to loft…
Please can you help me what I'm doing wrong?
https://cad.onshape.com/documents/fa63574f5a933802d9bbff69/w/6e771154e46a93897abccb2f/e/0347f4766523e4fd2f1fbd27?renderMode=0&uiState=6824a7ccd89b614b7a420dbc
  • afalzate13afalzate13 Member Posts: 54 PRO
    Is this what you're trying to do?
    Loft is great to use between two sketches where they share the same number of vertices. It's best to loft from one ellipse to another and maybe add some splines as paths to guide how the loft flows from one shape to the other.
  • MDesignMDesign Member Posts: 1,285 PRO
    Hard to say what your really going after but maybe this is going in the right direction? You will be well served to use the learn.onshape.com site to learn more about how to use lofts, guides, paths etc. Based on what you have selected in your loft feature, you might not have a good grasp on the basics of the tool.
