how do I extrude the surface enclosed by the selected edge?
Christopher_Moutoulas
Member Posts: 40 PRO
Site's 'cad.onshape.com' robots.txt did not allow access to the url.
Use the Fill feature first, then Extrude the face of the filled surface. Or you could create a sketch and apply the Use or Intersect sketch feature, then Extrude the sketch region.
RENDERCAD
rendercad.ai - Photorealistic product rendering.
How cool would it be you could just select some edges and THEN extrude revolve etc. adding in a plane axis or surface to complete the feature. I found myself trying to do the same as OP early in the learning process.
