need help with cylinder
jose_luevanojose_luevano Member Posts: 2
i am trying to put holes evenly spaced in the center if this face and i drew it on a plane and wrapped it solid but the entrance is the right size but then gets squished due to curve any way to just make the hole a solid 4.6 mm all the way thru
  • S1monS1mon Member Posts: 3,835 PRO
    Use the hole feature and pattern it radially.
