Problem with sweep
peter_patonpeter_paton Member Posts: 43 ✭✭
https://cad.onshape.com/documents/fa1ca25753015222ccc78242/w/539dfcfd740f84ec267c79e1/e/577b4a4d49546eb468a31dc2
Hi, need some help again! I am attempting to complete the part in the above document by merging the screw flights so they are continuous along the profile. I have tried the boolean union, but this brings back an error. Can someone advise how to do this?
Another related question is why I cant get the helix to extend over the joint line since it is not two parts?
Thanks in advance.
Peter
  • GregBrownGregBrown Member, Onshape Employees, csevp, pcbaevp Posts: 370 image
    The Part 2 intersects the Part 1 at a knife edge, meaning the Boolean will fail with the error message you are seeing "Boolean operation would result in a non-manifold body"
    Solution is to use a Replace face feature after the first Sweep to get rid of the "hanging" face. That small face is highlighted here. Replace it with the conical face and you'll be ok.
  • peter_patonpeter_paton Member Posts: 43 ✭✭
    edited May 2025
    Ha ha I wouldn't have spotted that in a month of Sundays! Thanks for the advice, much appreciated.
    Worked a treat, thanks Greg
