Need help extracting my Drawings microversionID
Ace_CaoileAce_Caoile Member Posts: 10 PRO
Need help..I embedded a web app to onshape as an Iframe via Oauth...
In the extension tab I added the below string to my Action URL
?did={$documentId}&wv={$workspaceOrVersion}&wvid={$workspaceOrVersionId}&eid={$elementId}&mid={$microversionId}
It's supposed to extract the parent Onshape URL's did (documentId), wv (workspaceOrVersion), wvid (workspaceOrVersionId), mid (microversionId), and eid (elementId)
It's able to extract these parameters inside Part Studio, and Assembly without any problems, but when I open it in drawings, I am not able to extract the mid (microversionId).
  • Caden_ArmstrongCaden_Armstrong Member Posts: 393 PRO
    Weirdly microversionId is not in the "supported" listed for element right panel:
    https://onshape-public.github.io/docs/app-dev/extensions/#element-right-panel
    But maybe put in an improvement request for it to be supported.
    Until then, if you just need the current microversion, you can get it with this endpoint:
    https://cad.onshape.com/glassworks/explorer/#/Document/getCurrentMicroversion
