How can I programmatically create a plane at an arbitrary orientation using the Onshape REST API?
test_user981f116ab204f6dbbdfbe6f0
Member Posts: 4 ✭
Hi everyone:
I’m working with the Onshape REST API to programmatically generate sketches and extrudes. I’ve successfully used the API to:
- Create sketches on standard planes (e.g.,
"Front") - Define circles, rectangles, and line segments
- Extrude sketches into 3D geometry
Now I want to define a new reference plane — for example, a plane normal to a line, located at a specific end-point. I need this plane so I can define a sketch on it and extrude it.
Another option would be to extrude a sketch (circle or square) along a line-segment.
I can't seem to find documentation on how I would go about this outside of the examples (for a circle and extrude) in the API docs.
What are you trying to achieve? Its possible to do what you are looking for, but depending on what your end goal is, there might be a better way.
Custom FeatureScript and Onshape Integrated Applications
