how to put a bend in a flat sheet metal piece
chEZpotatochEZpotato Member Posts: 4
I need to create a 136 degree bend on the line shown and I am at a loss 🤷‍♀️ I made the part by creating a flat dimensioned sketch and a construction line where the bend should be. I extruded the sketch to 3/16in (the thickness of the sheet metal being used and added a steel material to the part. When I go to the bend tool it recognizes the construction line for where I need the bend put does not register the part as a sheet metal face to bend. I've googled everything and I cannot for the life of me figure out how to create this so that it works in the sheet metal model mode.
  • GregBrownGregBrown Member, Onshape Employees, csevp, pcbaevp Posts: 370 image
    You have not started a sheet metal part. You'll need to do that… instead of Extrude 1, use a Sheet metal model feature and select your Sketch 1
    Then use the Bend feature
