How do i fix a ridge appearing on a loft that is supposed to be smooth?
https://cad.onshape.com/documents/7b729b678209fe13403e7fce/w/6280530c7ebb748c87e46a9d/e/b8fc1bfb0e204f1d94736962?renderMode=0&uiState=68489b4cb4d8bd6a38a43e3f
I am recreating a watering can from a picture and i want to 3d print it. This is the picture:
Untitled Image
I got stuck at the tube part where the water comes from. I made 3 profiles on 3 separate planes all angled differently, I connected them with a loft and set the end condition as normal to profile with a magnitude of 1. I used match connections, tried making the connections in multiple ways but all attempts resulted in a ridge (or what should i call it) on the tube, which prevents me from shelling it to make water go through. I can kinda see what the issue is when i turned on isocurves but I have no idea how to fix such a problem.
This is what it looks like from a section view from the end of the tube:
This is not the first time I am having an issue with lofts, is there a set of general rules to follow when using lofts to prevent issues?
The printing itself will be really challenging but that is a problem for future me :D
