Ball Screw relationship
abhinav_kenchi244abhinav_kenchi244 Member Posts: 2
Heyy! I want help regarding this I made this cylindrical screw and the threading which was required and then now I have to move this small ball along the thread but I am not able to use cylindrical mate and and screw relation to move the ball along the threaded path. can anyone help with this ?
  • David_YL_NguyenDavid_YL_Nguyen Member, Onshape Employees Posts: 180 image
    Hey @abhinav_kenchi244,
    If you can share a public link to your document, people can have a closer look.
    You can try out a tangent mate, between the ball surface and the channel. You can also have a look if this Tech Tip can be helpful: https://www.onshape.com/en/resource-center/tech-tips/advanced-mating-pin-slot-tangent-mate
  • GregBrownGregBrown Member, Onshape Employees, csevp, pcbaevp Posts: 361 image
    Something like this can be done easily:
