helping with the creation and smoothing of wings
TardisTardis Member Posts: 7
hi, i am not really sure how to smooth out these edges as fillet and loft doesnt really work
I want to make the edges graduelly thin out like a spitfire or any plane wings
picture:
the link for the project is here:https://cad.onshape.com/documents/8109b47ffe14c14d58f03150/w/09bc9c8a0788bd0a8a627fa1/e/b3636e395fd4151cc51a3063
thanks
  • GregBrownGregBrown Member, Onshape Employees, csevp, pcbaevp Posts: 382 image
    If you look at the curvature of the original curve you created in the Profile generator feature you'l see it is not optimal for smooth surface creation. Since this curve is the basis for all subsequent features, you will face difficulties.
    I have found that using two splines: one for the top surface, one for the lower surface is a good idea. The Profile generator offers this as an option, however the curvature of the resulting splines is still not create (since it is still using a fit spline on "noisy" data under the covers of that custom feature )
    Last year I helped Holbrook Aerospace create a new Custom feature that tries to address this - HAVF Profile
    Alternatively you can use an Edit curve feature after the current Profile generator and do some reapproximation of the sketch, before it is used in the extrude and other features.
