Namespaced Variable names
noé_perard_gayotnoé_perard_gayot Member Posts: 4
Hi !
I happen to have multiple ID,OD, etc. variable in different parts studios and documents. I'd like a way to be able to namespace them (like in C++ ) instead of typing OD the name Bearing0.5::OD would be clearer, while avoiding superfluous manually naming dimensions. Also it would be extremely helpful to be able to have a global dictionary of sizes like M3::NS for the nominal size, M3::Pitch for the pitch etc… and if those could be available to every user, I'm sure It'll make all of our sketches simpler and reuse correct dimensions for many common spare parts.
I'm sure this would require a major code refactor, but I can assure you, the reward is way worth the trouble !
  • eric_pestyeric_pesty Member, pcbaevp Posts: 2,631 PRO
    If I understand correctly ,this looks a lot like what variable studios are meant for?
    You can also use a custom feature (with drop downs) to create a "set" of variables in one go (for example the (OD and Pitch) for a selected fastener, but you have to create it in every part studio you need it, and it's not available in assemblies (unlike the variable studio).
  • MichaelPascoeMichaelPascoe Member Posts: 2,818 PRO
    edited June 2025
    You could split up your code into functions and have the variables locally within those functions. If you really wanted to you could then store those in a separate feature studio and import them.
    Another way to do it is to store all related variables within a map. You could call that map the name of your bearing. For example:
    var Bearing0_5 = {};
    Bearing0_5.OD = 0.75 * inch;
    var usageTest = 2 * Bearing0_5.OD;
    There are also lookup tables… but I don't want to get into those. Kind of a headache.
    Maps and FeatureScript can be used directly within the part studio inputs as well. In case you weren't talking about FeatureScript studios.
    RENDERCAD
